front suspension problem
Old Mar 25, 2009 | 08:55 PM
jessebasiuk's Avatar
jessebasiuk is an unknown quantity at this point
Default front suspension problem
OK Ive got a some what loud clunking noise coming from my left front wheel it happens when going through potholes and any kind of bumps so i need some help figuring this out and it is worse in 2wd than 4wd (still clunks but seems to not be as bad)
things i have replaced
- all ball joints the left lower one looks a little worn
- ideler arm and tie rods
- sway bar links
-sway bar bushings
- cv joint not new but boots are still on
possible problems
- left lower ball joint but there is no play in the wheel
- shock bushings
- upper or lower control arm bushings
-torsion bars/ keys
so let me know what you think it is.
Old Mar 25, 2009 | 10:57 PM
Swain's Avatar
Swain is an unknown quantity at this point
Check the torsion bar mount as well, give the torsion bar a shake towards the rear they are pretty cheap to replace and could cause the noise you are telling us about.
Rottidog
Jan 26, 2010 07:37 PM
shawn
Mar 22, 2009 05:58 PM
Marcin
Suspension Tech
Jan 25, 2007 06:08 PM
cimbali
Jun 30, 2006 05:07 PM
95chevyflames
Suspension Tech
May 8, 2005 07:20 PM
