Suspension Tech Have a question about modifying your suspension? Ask it here.
front suspension
Old Feb 25, 2005 | 09:02 PM
95chevyflames's Avatar
95chevyflames is an unknown quantity at this point
Default front suspension
i have a 95 s-10 blazer 4 wheel drive. Has anyone had any touble with their front suspension popping and sqeaking?
Old Feb 26, 2005 | 12:16 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: front suspension
i had to diagnose an '03 impala that made a bunch of noise from the front end...turns out the control arms' bolts and engine cradle bolts were all really loose. i guess it came from a body shop and they must have forgotten to tighten everything. so id start out making sure everythings tight under there. if thats not it then it could be balljoints, tierod ends, bushings. so check all those too.
Old May 8, 2005 | 07:20 PM
kalito's Avatar
kalito is an unknown quantity at this point
i have a 95 blazer and i had a popping sound that is was coming from the top of the inner fender and i took it to several mecanics shop and nothing, i drve over a bump back and foward and tried to find the problem and i came to the conclusion the it was the hood... put a little cushing problem solved...
Rottidog
Jan 26, 2010 07:37 PM
shawn
Mar 22, 2009 05:58 PM
TripleBlackBlazer
Feb 15, 2007 01:37 AM
Marcin
Suspension Tech
Jan 25, 2007 06:08 PM
cimbali
Jun 30, 2006 05:07 PM
