Front wheel massive angle
Old Oct 10, 2017 | 06:33 PM
Default Front wheel massive angle
So I have done the fron ball joint and hubs recently, shocks a few months ago and now my front end sits like this... and I'm not sure if the front upper control arm bushings would have an effect like this. Or if I have another issue. I have don't the Good old woble test for the joint and checked the hub and they are good.
Any ideas?
Attached Thumbnails Front wheel massive angle-20171010_191803.jpg   Front wheel massive angle-20171010_191755.jpg
Old Oct 10, 2017 | 08:42 PM
chevyriders's Avatar
Most often I've seen that issue from bad ball joints or hubs. Being that you've already replaced those and they are good, I would suspect control arm bushings too. I suppose it's also possible that you're way out of alignment- but it doesn't seem likely that it came out of alignment that much for no reason.
Old Oct 11, 2017 | 04:02 AM
dieseldyr's Avatar
dieseldyr is on a distinguished road
Try to compensate by tightening the torsion bar keys?
Old Oct 11, 2017 | 05:58 AM
Would the torsion key tightening affect the one side only?
Old Oct 11, 2017 | 06:27 AM
If you only tighten one torsion key it will only adjust the one side. I wouldn't recommend taking that route though, it will just throw everything out of alignment further if you adjust that. I would take it to a shop,point out the issue and ask for an alignment. If the issue is the bushings and not just a bad alignment- they will tell you that, and you can go from there
Old Nov 18, 2017 | 05:12 PM
So stupid me. When the old bushings went they threw the control arm off angle. And when I installed the new ones, I didn't re check the angle after. So needless to say, after a little adjustment and some unwanted wear. She's straight and good again. Now to fix my pull to the left.
Old Nov 18, 2017 | 06:02 PM
newguy's Avatar
It may look straight, but most likely its not
Old Nov 18, 2017 | 07:38 PM
No not without hooking it up... but compared to what it was she looks straight lol... I got a bit of adjusting to do tomorrow when the rain stops. But I'm not too worried about having it dead on... as long as I don't kill my tires I'm happy ��
s10blazer20
Jan 27, 2011 04:38 PM
bill9000
14
Jan 7, 2011 07:54 AM
dcshoes1
Aug 6, 2009 01:20 AM
Tippman7641
May 24, 2008 02:50 AM
avorg
Mar 15, 2008 11:52 PM
