Front wheels catching in sharp 4wd turns?
Old Nov 19, 2009 | 07:16 PM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
Default Front wheels catching in sharp 4wd turns?
Kso.. Bought this blazer a couple weeks ago from my buddy who I came across on here last night.. everything works fine (after I put a directional switch in the first night) except the 4wd seems to try and lock up the front wheels when I have it engaged and when I turn sharp and slow, say into a parking space. So far I've only made sharp right turns and haven't tried it with the wheel to the left. It does this going forward and backing up. Anyone have this problem before that could give me some insight?
Old Nov 19, 2009 | 07:20 PM
huntersblaze's Avatar
huntersblaze is on a distinguished road
Is this happening while on dry pavement?
Old Nov 19, 2009 | 07:22 PM
96chevblazer's Avatar
Do you mean it kicks back and forth, if so its working right, if there is no difference between 2 and 4wd them there is a problem
Old Nov 19, 2009 | 07:29 PM
Yes on dry pavement.
And it's not really kicking back and forth so much as just not wanting to go without giving it extra gas..
Old Nov 19, 2009 | 07:34 PM
Don't use 4 wheel drive on dry pavement because it locks the front and rear axles together. When turning each wheel moves a different distance and when this happens on a surface like snow, mud or sand the wheels slip a little and everything's fine, but on dry pavement there is to much traction to slip and it causes binding.
Old Nov 19, 2009 | 07:35 PM
sounds like the front axle is engaging but the t-case isn't.
I'm assuming you have push button 4x4
When you try to engage it do you hear a click sound from the t-case?
Old Nov 19, 2009 | 07:39 PM
- That makes sense, everything goes fine in 2wd.
- Yes I do have push button. I haven't really been listening for a click but then again the super 44 doesn't really grant much to listen for. Than again... the t case does engage as well b/c I started slipping the rears on wet pavement a few days ago then I pushed the 4 Hi and I regained traction.
Old Nov 19, 2009 | 07:48 PM
Then it would be the front axle not engaging and the t-case engaging, I just had this problem with my blazer.
The problem probably is the vacuum actuator.
Being that you have a 95 I'm not sure where your vacuum actuator is, It may be under the battery tray like 96+'s are.
But once you find this, https://static.am-autoparts.com/item/dc058a8127.jpg
Check to see if the seal (on the bottom of the pic) is ripped. If so this is your problem!
Also check if the vacuum line is hook and if it has suction. You can test it by pulling it off, starting the truck and putting it in 4x4, then put your finger over the hole and feel for suction.
Old Nov 19, 2009 | 09:13 PM
No, that would be everything working correctly. When locked into 4wd, there is no speed difference between the front and rear driveshafts. While turning, all 4 wheels are taking different paths. The drivetrain is binding up due to this. One tire has to slip to relieve the bind. Extra power is required to make this happen. Completely normal.
Old Nov 20, 2009 | 08:26 AM
Well that solves it! Thanks guys for your help. I'm still a newbie to 4wd being this is my first truck and all so I've got a bit to learn. Wonder how many times I'll get myself stuck...
