front wheels not spinning
Old Mar 2, 2011 | 01:03 AM
cutthroatxxx's Avatar
cutthroatxxx is on a distinguished road
Default front wheels not spinning
Hey guys just bougt a 2000 blazer &found out I have low compression on #4 then to add insult to injury I got stuck in the mud&when I put it in n&put it in either 4 hi or 4 lo it will click &feal like it goes in gear but while my back tires spun the front didn't move.Also the abs light is on any ideas?
Old Mar 2, 2011 | 07:06 AM
Low compression could be due to a head gasket, valve, or ring problem.
Your front axle engagement issues are well documented on the forum --> Common 4x4 Problems.
If the abs light is on, that means there is a problem and the EBCM has stored codes present and waiting to tell you what it thinks is the problem. Getting those codes read by a compatible scan tool would be the first order of business.
KellenR
Oct 22, 2013 06:01 PM
ComputerNerdBD
Jan 12, 2011 07:12 AM
Chadoo951
13
Jun 30, 2010 01:59 PM
branswiss3
Street N Strip
17
Mar 3, 2010 01:08 PM
mboehler
Jan 16, 2009 07:16 AM
