G80 repairs
Old Nov 13, 2018 | 10:57 AM
nomoresubies's Avatar
nomoresubies is on a distinguished road
Default G80 repairs
Have a 2001 G80 rear that does not "lock" when there is differential tire spin. I have read as many threads as I could find about it but maybe I did not find them all. Anyway, not trying to re-beat a dead horse...
So I need to fix this differential. Was told it just needs new clutch packs. How difficult is this? Do I need to pull axles? Are there codes on the axle housing that would give me a clue as to if it is truly a G80? If it is a "locking" rear are there clutches and the locking cams?
I had a 1967 Camaro with a 12 bolt Posi and when jacked up both rear wheels would spin in the same direction when rotated by hand. Was told the G80 does not do that. Mine spin in opposite directions.
Any help here would be appreciated. Waiting to hear back from Eaton at the moment also.
Thanks.
Old Nov 13, 2018 | 11:10 AM
Rusty Nuts's Avatar
Have you confirmed there are clutch packs in the carrier? Gov-loc's do not use clutch packs. They do make going to a limited slip not an option if they fail. Yours may have been replaced/upgraded.
Old Nov 13, 2018 | 11:30 AM
Have not opened up the cover yet. Trying to get some clues prior to doing so...
Old Nov 13, 2018 | 11:31 AM
Supposedly this is a stock 2001 G80 coded rear from the glove box sticker...
Old Nov 13, 2018 | 12:06 PM
Rusty Nuts's Avatar
RPO code zr2?
Old Nov 13, 2018 | 12:46 PM
You sure about that?
Old Nov 13, 2018 | 12:49 PM
RPO code zr2?
VIN showed up as ZR2 as well as glove box sticker...
Old Nov 13, 2018 | 01:08 PM
Rusty Nuts's Avatar
Then it should be a 10 bolt, 8.625" ring gear, 3:73 ratio.
Old Nov 13, 2018 | 01:25 PM
Rusty Nuts's Avatar
Apologies for the misinformation. Too many rear ends in my head right now.
Old Nov 13, 2018 | 01:56 PM
