Grinding noise from front end while driving!
Old Oct 14, 2010 | 07:00 AM
caseroj's Avatar
caseroj is on a distinguished road
garynye30 -
I am glad it worked out for you. Did you notice at all if the bearings had come loose? On mine that was the case. At first I thought the bearings were worn and would need replacement but when I disassembled everything and inspected them they looked fine? So I just greased them up and reassembled everything making sure to tighten the nuts properly. After that the problem and the noise went away.
Old Oct 15, 2010 | 06:34 AM
garynye30's Avatar
garynye30 is on a distinguished road
I took a look at the bearings. Could see nothing wrong with them. So I did not even mess with them. The hub was making a grinding noise when I turned it by hand. The only other item I found that looked bad was my upper ball joint on the driverside. Other then that it seems to be fine now.
Bolbol
Feb 2, 2015 02:55 PM
bowshooter1
Mar 10, 2012 06:31 PM
chad911
Feb 2, 2012 07:41 AM
irocrob
May 21, 2010 05:53 AM
JZRALNC
Apr 14, 2008 11:16 PM
