grinding/scraping noise and violent shaking straight and worse turning
Old Dec 14, 2014 | 08:29 AM
gjeffries1987's Avatar
gjeffries1987 is on a distinguished road
Default grinding/scraping noise and violent shaking straight and worse turning
In my 2001 blazer lt, i noticed a used tire dealer put on a 235/70/15 instead of the 235/75/15 on my front passenger side and after changing the tire after a week, there was a scraping/grinding noise and shaking which became inoperable after driving to and from work twice. I recently changed the upper ball joint with a mechanic friend, and he forgot to put in the cotter pin, and also left a cable exposed (which may be getting caught in tire), i took care of these issues but its still got the scraping/grinding noise and violent shakes. Anybody have similar issues or an answer would help since the truck has been at my job for 4 days?
Old Dec 14, 2014 | 08:40 AM
rexazz2's Avatar
check the wheel nuts
that tire size should not matter
Old Dec 15, 2014 | 03:46 AM
newguy's Avatar
Also with the truck lifted on that side. Tire off ground turn wheel and check for the grinding noise. Grab the tire at 12 and 6 oclock and see if you can wiggle it and if there is any play. Also do this at 9 and 3 oclock. Could be a bad wheel hub
Old Dec 15, 2014 | 12:23 PM
I put in in the air on my break, and shook the wheel @ 9 & 3 and 6 & 12, no resistance. it shook a lot both ways. as for the grinding noise I heard it but it was low because I couldn't spin the wheel fast because there was grinding. I just changed a broken upper ball joint and I'm guessing it took another part down with it.
Old Dec 15, 2014 | 01:17 PM
newguy's Avatar
Bad wheel hub, not to hard to change just takes a little while. heres video on how to do it. You didnt wreck it, it was going on its own
Old Dec 16, 2014 | 12:17 PM
I looked underneath to check and see if the lower ball joint was failing, and instead found it broken.
Attached Thumbnails grinding/scraping noise and violent shaking straight and worse turning-camerazoom-20141215162123239.jpg   grinding/scraping noise and violent shaking straight and worse turning-camerazoom-20141215162125754.jpg   grinding/scraping noise and violent shaking straight and worse turning-camerazoom-20141215162129794.jpg
Old Dec 16, 2014 | 01:47 PM
newguy's Avatar
It looks like your lower a arm is cracked !
Old Dec 17, 2014 | 08:23 AM
Jamaroon's Avatar
I think that's just the shadow from the steering stop.
Sounds like you should be replacing lower ball joints and unit bearings as well. It'd be a good idea to look at the rest of the suspension and steering as well.
watzizname
Jan 2, 2015 03:01 PM
anthonyking
Mar 14, 2011 12:25 PM
ComputerNerdBD
Jan 12, 2011 07:12 AM
JZRALNC
Apr 14, 2008 11:16 PM
Brian J. Lesko
Feb 18, 2008 11:18 AM
