Help on ordering parts for a 99 ZR2 S10!!
Hi was going to order a full set of Ball Joints/Bearings & hubs/CV-Joints for my 99 S10 blazer ZR2 4wd, but a friend of mine told me that if I order the same parts for the base 4x4 blazer they would fit perfect! Is there any truth to this? If so what other parts can I order that will fit my ride?
I really appreciate the feedback! Chris |
RE: Help on ordering parts for a 99 ZR2 S10!!
Ok I think I just found what I was looking for!! I need to replace my ball joints & I found these parts on e-bay! The seller has a lot of stars and is a power seller, so I'm hoping for the best!
Would it just be smarter to buy ball joints or do I need all these other parts?http://i9.ebayimg.com/06/i/000/fa/65/8aa4_1.JPG Kit includes: [ul][*]2 INNER TIE ROD ENDS second design w/offset tie rod [*]2 OUTER TIE ROD END second design w/offset tie rod [*]1 IDLER ARM [*]1 PITMAN ARM [*]2 LOWER BALL JOINT [*]2 UPPER BALL JOINT [*]2 SWAY BAR LINK [*]2 ADJUSTING SLEEVES Thanks for your patience!! [/ul] |
For balljoints I never use anything but the Napa premiums expensive but said to be unbreakable. If you search around you'll see that a lot of hydraulic guys use them in their lowriders and hop with them.
I wouldn't touch that stuff on ebay at all guarantee all your gonna get is made in china crap that isn't in spec. For other suspension parts stick with moog. and replace only what you need to. As far as ordering parts for a base blazer check part#'s to make sure they fit. |
Your the best xmradioguy!! That really helps!! I'll drop by Napa tomorrow & check out what they have in stock!! Thanks for your help!!
