Help on ordering parts for a 99 ZR2 S10!!
Old Jan 13, 2009 | 10:43 PM
chrisblaze's Avatar
chrisblaze is an unknown quantity at this point
Default Help on ordering parts for a 99 ZR2 S10!!
Hi was going to order a full set of Ball Joints/Bearings & hubs/CV-Joints for my 99 S10 blazer ZR2 4wd, but a friend of mine told me that if I order the same parts for the base 4x4 blazer they would fit perfect! Is there any truth to this? If so what other parts can I order that will fit my ride?
I really appreciate the feedback!
Chris
Old Jan 14, 2009 | 01:01 AM
chrisblaze's Avatar
Default RE: Help on ordering parts for a 99 ZR2 S10!!
Ok I think I just found what I was looking for!! I need to replace my ball joints & I found these parts on e-bay! The seller has a lot of stars and is a power seller, so I'm hoping for the best!
Would it just be smarter to buy ball joints or do I need all these other parts?
Kit includes:
[ul][*]2 INNER TIE ROD ENDS second design w/offset tie rod [*]2 OUTER TIE ROD END second design w/offset tie rod [*]1 IDLER ARM [*]1 PITMAN ARM [*]2 LOWER BALL JOINT [*]2 UPPER BALL JOINT [*]2 SWAY BAR LINK [*]2 ADJUSTING SLEEVES
Thanks for your patience!!
[/ul]
Old Jan 14, 2009 | 01:24 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
For balljoints I never use anything but the Napa premiums expensive but said to be unbreakable. If you search around you'll see that a lot of hydraulic guys use them in their lowriders and hop with them.
I wouldn't touch that stuff on ebay at all guarantee all your gonna get is made in china crap that isn't in spec. For other suspension parts stick with moog. and replace only what you need to. As far as ordering parts for a base blazer check part#'s to make sure they fit.
Old Jan 14, 2009 | 01:46 AM
chrisblaze's Avatar
Your the best xmradioguy!! That really helps!! I'll drop by Napa tomorrow & check out what they have in stock!! Thanks for your help!!
Buttermin
Jun 14, 2013 01:38 PM
zcat23
Sep 29, 2010 10:30 AM
Dano01
Jul 15, 2010 05:46 PM
wlorton
Jul 12, 2010 10:37 PM
mellon101
Nov 28, 2006 06:21 PM
