Help! Pitman arm question
Old Nov 22, 2013 | 02:45 PM
13ogart's Avatar
13ogart is on a distinguished road
Default Help! Pitman arm question
I own a 2005 Gmc jimmy 4x4 .....so I've done all my research and watched all the videos and still ran into problems. I took the power steering gear box off to put the new pitman arm on everything went fine... put it all back together all the lines are where they should be... fluids in fire it up now not sure if its the gear box but there is a rubbing sound.. and the steering does not feel right any thoughts?
Old Nov 22, 2013 | 02:46 PM
jpimp's Avatar
jpimp is on a distinguished road
I just did a pitman arm on a 99 a few weeks ago.
I still need wheel alignment but everything else is fine.
did you get aligned yet?
did you bleed the power steering?
Old Nov 22, 2013 | 02:57 PM
13ogart's Avatar
Havent done either i just stopped to get some more research before i break something else.. didnt even think of bleeding the power steering
Old Nov 22, 2013 | 03:02 PM
jpimp's Avatar
just raise front wheels off the ground
take the cover off the fluid
and turn the steering wheel lock to lock about 15 times or so
all the air should work itself out the top
Old Nov 24, 2013 | 11:48 AM
13ogart's Avatar
Sorry for the late reply everything is good now i guess i don't have a choice about getting an alignment done how much was yours out by?
cartunez2004
Apr 9, 2011 09:01 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
