How do you change a wheel hub?
Ok so I have another problem with my truck. A few weeks back I heard a humming noise coming from the passengers side front wheel, I didn't pay much attention to it because i knew what it was. But last week I had to do brakes because the passengers side was metal to metal on the inside. I had just replaced front and rear " rotors, pads, drums, and shoes" on JAN 21st OF THIS YEAR!!!! and maybe I put 4-6k miles on my truck in that time but I looked at the hub and it really didn't move much at all maybe 1/8" to 1/16".
However today because I was bored I jacked the front end up and the passengers side wheel moves around an inch. I also found out that the bolts on my front sway bar are backing out, I've lost 3 bolts and the rubber on the drivers side and I think there are 2 bolts backing out on the passengers side. Would these problems be related? Also it's throwing a code that the passengers side ABS wheel sensor is bad.
How much work is involved with changing the wheel hub?
you get the wheel sensor code because the hub is bad
they are really easy to change
just pull it apart like you are doing brakes, remove the caliper and rotor. then take off the 36mm center nut, there are 3 bolts behind the spindle that hold the hub on, 15mm i believe. remove those than bang the hub off. slide the new one on, bolt it in and re assemble the brakes
Alright man cool, only thing I'm going to have an issue with is the 33mm nut i have nothing that will fit that maybe a pair of channel locks will work. Would anyone know about the stupid bolts backing out? Should I just remove my sway bar? I tend to drive like I'm on the run when I'm by myself and when turning to the left it feels like I need to turn my truck a lot more to make it turn I don't know if the sway bar missing a bracket would make it like that or if it is because of the wheel hub?
i would invest in a 36mm socket its on there pretty tight
I'll have to see if I can find a "loan a tool" for a 33mm socket, what drive would that be cuz I have a 3/8 and a 1/2" drive wrench
Thanks for the help, but im afraid that it is a dead link, I used the search before posting and i didn't find that
You can buy the 3/4 drive socket for about 8 dollars at any tool place, and an adapter to go from 3/4 down to 1/2 so you can stick it on your breaker bar. You will never loosen that nut with channel locks, you might strip it and break your channel locks, but its not coming off. Tighten it to 150 foot pounds.
thanks man, so on my 1st gen is the center nut a 33mm or a 36mm like in that how to?
