How often you get an alignment?
Old Aug 14, 2018 | 01:16 AM
Default How often you get an alignment?
Hi all,
I was wondering, how often do you get a front-end alignment or have it checked? I would imagine this might differ depending on if you have a stock front end or a suspension lift.
Christine
Old Aug 14, 2018 | 01:39 AM
GreenBlazer2002's Avatar
Hi all,
Christine
As long as it's not pulling in either direction and I don't have any uneven tire wear, never.
Old Aug 14, 2018 | 03:05 AM
Cimmerian's Avatar
What GreenBlazer said, but I get it checked when I buy new tires just to make sure.
Old Aug 14, 2018 | 03:54 AM
newguy's Avatar
maybe after a heavy pothole winter but usually after new tires
Old Aug 14, 2018 | 04:40 PM
Same boat as green... no pull or wear, no worries
Old Aug 14, 2018 | 07:39 PM
chevyriders's Avatar
+1 for only if I see irregular wear or feel pulling.
Save for if an adjustable suspension/steering component was replaced, or if there was direct force to a wheel(related to an accident, very hard curb hit, etc) in the case of a direct hit to the wheel, I would reccomend a preemptive alignment. A set of tires far exceeds the cost of an alignment! Any collision job that comes in our shop with a wheel that was hit during the accident gets sent out for alignment. Sometimes it doesn't take much lateral force to throw it off, or bend a part.
Old Oct 14, 2018 | 07:41 AM
puttster's Avatar
If the camber or castor needs alignment and the only way to do it is with the spacers, does it cost extra? Or when they say "Alignment $80" that's for everything. Seems like it would cost extra, that's a lot of work on a 2wd blazer. I just never asked.
Old Oct 14, 2018 | 11:21 AM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Only if I notice something odd while driving, or if I have work done on the front end suspension or steering.
Old Oct 15, 2018 | 06:59 AM
How about in my case, where I've lowered it 2 inches front and back via blocks in the rear and shorter springs up front? Would a shop still be able to align it properly?
Old Oct 15, 2018 | 09:42 AM
I would think it is possible for lowered vehicles, just like I found out with my liftted suspension, that a shop can do an alignment. I might be harder for them to get into spec. I was told they had to go to about the extreme of the adjustments to get mine done. I've seen ball joints that are offset so that the alignments can be done. I'm pretty sure it is a solvable problem.
