Im having trouble with my 4wd
Old Aug 4, 2011 | 12:23 PM
jsum73's Avatar
jsum73 is on a distinguished road
Default Im having trouble with my 4wd
hi all im new and have a 99 blazer..the trouble im having is at first the 4wd drive wouldnt engage, the push button lights would just blink..i found a vacuum line going to that thing under the battery cut so i replaced it.. now the 4wd drive is engaged and wont disengage..just blinks once again..where should i go next...oh yeah.you can hear the shift motor running but its apparently not doing anything
Old Aug 4, 2011 | 12:24 PM
Classic questions... How many buttons are on the dash (3-button = NV233 / 4-button = NV236)? Have you pulled the codes? The NV233 can be done easily as described in the tech article section. The NV236 requires a scan tool capable of accessing the TCCM (transfer case control module).
Check out the Tech Article (DIY) section for more helpful 4wd related threads.
Old Aug 4, 2011 | 12:27 PM
jsum73's Avatar
i have 4 buttons...auto 4wd, 2hi 4hi 4lo and no i havent gotten codes yet but i can go do that if that would help in troubleshooting
Old Aug 4, 2011 | 12:45 PM
Is the service 4wd light on in the dash? If so, getting the codes read from the TCCM will help give direction to the diagnosis.
Try disconnecting the vacuum hose from the vacuum solenoid on the firewall and see if it will shift into 2wd. If it does, then the solenoid might be bad or the lines may be on backwards.
Old Aug 4, 2011 | 01:13 PM
jsum73's Avatar
i pull the vacuum hose off but it wouldnt shift back to 2hi, but now the thing wont engage back into 4hi..lol..its possessed
Old Aug 4, 2011 | 02:16 PM
Pull the passenger side kick panel & take a look at the electrical connections on the TCCM. While you have things apart, measure the resistance of the switch in the dash at the switch as well as at the TCCM. The wiring diagram & resistance values can be found in the NV236 tech article.
Old Aug 5, 2011 | 10:27 AM
jsum73's Avatar
thats out of my league..im not much of a mechanic..
tjbmxrider
Mar 25, 2008 06:09 AM
lad446
Dec 13, 2007 09:30 PM
97Blaze
Jan 22, 2006 06:33 PM
ivannj
Jan 13, 2006 11:47 PM
