intermediate shaft removal ?
Old May 28, 2010 | 08:45 AM
kpzrx's Avatar
kpzrx is on a distinguished road
Default intermediate shaft removal ?
a question for my new mechanical friends : i thought i was about to finish up a head job on this charity work when i found i no longer had room to install the exhaust manifold, rather than removing the head again i found i could remove the steering shaft but i cant seem to figure out that white plastic piece that joins the upper shaft to the flex joint shaft or if i even have enough room axially to disengage the splines . 1997 4.3 blazer any suggestions would be greatly appreaciated . kpzrx
Old May 28, 2010 | 11:13 AM
It may take some force, but the shaft should compress allowing it to disengage from the splines on the gear box.
Old May 28, 2010 | 12:04 PM
kpzrx's Avatar
Default itermediate shaft thankyou but
do you think ill still have room to swivel that shaft up and out of the way far enough to install that manifold ? again thanks for the help
rrmagg06
Sep 13, 2020 08:36 PM
PMeloy
May 10, 2011 03:37 PM
Hellraiser
Mar 24, 2011 05:06 PM
saxman_IN
Mar 17, 2011 05:09 PM
SniperX13
Mar 16, 2006 09:57 PM
