Intermittent gear grind noise from front
Old Nov 4, 2011 | 10:30 AM
DKSDAD's Avatar
Default Intermittent gear grind noise from front
Just putting a question out there for you all. My 95 has developed an intermittent gear grinding noise that sounds like it is coming from the right front. I have noticed that on 4-5 times in the past 2 weeks it sounds like gears are grinding together and then they set in with a slight clunk. My torsion bars are cranked about 1.5 inches and am thinking maybe the axle splines in the right front are walking out a bit. I have not taken notice if the wheels are turned when I first start to drive so I will keep an eye out for that. Any input would be appreciated.
Tony
Old Nov 4, 2011 | 10:41 AM
When does this occur? Does it happen when you are in 2wd or 4wd? It quite possibly could be a problem with your front axle engagement system.
Old Nov 5, 2011 | 03:33 PM
DKSDAD's Avatar
So far only in 2 wheel drive, I have not used 4 wheel drive in about 2 months. I did pop trans (auto) into neutral when it was making noise and the noise was still there. By the time I went to engage the 4 wheel drive the noise was gone.
Old Nov 27, 2011 | 08:16 PM
tsLongarms's Avatar
tsLongarms is on a distinguished road
Exact same problem occured recently on my 97. The passenger side steering stabilizer mount assembly was rusted all to hell and broke. I fixed that and it was fine for a little while but eventually the grinding noise came back and started to slightly pull to the right again. Nothings broken as far as I can tell. Also my problem occurs in 2wd. Haven't tried 4wd yet.
And when I disengage the clutch, it doesn't help. As always, any help is much appreciated.
84_K5
Dec 2, 2010 01:38 PM
vdubb16
Jan 11, 2010 11:26 PM
Barc
Jan 13, 2009 09:51 AM
jsmz
Oct 19, 2008 02:58 PM
mdkuni
Oct 3, 2008 01:04 PM
