Jimmy 4x4 Actuator
Old Jun 2, 2011 | 06:31 PM
antman94's Avatar
antman94 is on a distinguished road
Default Jimmy 4x4 Actuator
I noticed a leak starting to develope where the Actuator cable housing meets the front differential (I believe its that it might be the transfer case I dont completely remember) But I took the three bolts out that held it in place and I cant figure out off of the differential. Does any one know how to disconnect that actuator cable and also how to remove that housing? Also, where can I get a gasket for the housing at? (since thats is my goal to replace) I cant seem to find one anywhere online. thanks in advance
*File attatched*
I need the gasket that goes all the way to the right of the piece on the right. (btw this not my picture, I also need to figure out how to disconnect that cable)
Old Jun 7, 2011 | 04:06 PM
antman94's Avatar
Got the cable disconnected it was just a spring clip. I still cant figure out if there is a gasket that goes between here since it does not show on the schematic. I also took a picture between the two pieces to see if that helps. Thanks (on the schematic its around #10)
jdog2pt0
May 29, 2012 08:56 PM
markrd
May 8, 2009 01:39 PM
toofancy83
Dec 11, 2008 11:23 AM
mx534
Nov 25, 2006 10:14 AM
ryansoxfan
Aug 16, 2006 09:23 PM
