just found broken part in suspension
Was putting in new break pads when I found out this part was broken. I'm going to say it is the A arm. But idk. The part with the red bushings has snap off. I'll add pictures when I log in on my computer, currently I'm on my phone
the first pic shows where the part snapped. The second pic just shows a better angle of exactly what part snapped. ANy help identifying the part or maybe even pointing me in the direction of where to buy the part would be appreciated. could it maybe be called the pitman arm? ive been looking for parts online that resemble it, but im still not sure
Yeah thats an easy but time consuming fix! I would replace the control arm myself. Just cause its probably going to cost about the same unless you know someone who can weld really well. Then while your at it you can replace that torn up boot on your cv shaft
well thanx for all the help. I have a mechanic friend who can weld pretty darn good. I just wanted to know what i was talkin about before i called him out here. So the broken part is the lower control arm? ANd ya i plan on replacing it, along with the rest of the battered parts there.
I broke mine on both sides over the years. Just weld it up and put a small gusset to support it better. You don't need to pull the tab off the link, but make sure the vehicle is on a level surface when you weld it back on.
It seems it has been welded on before, and what broke was the welds. I was looking for replacement parts this morning, but when i see the lower control arms, i dont see this flange in the picture. Am i overlooking it in the pic? or is it a seperate part to be purchased alone??
