Leaf Spring Questions
Old Mar 17, 2013 | 11:52 PM
Emsblazer72's Avatar
Emsblazer72 is on a distinguished road
Default Leaf Spring Questions
I have some questions I hope someone can answer for me. First I would like to start by asking where can I get a good set of leaf springs? Will/can the leaf springs add height? I know that since my blazer is now sagging the new ones will and some height but can they add 2,3, or even 4 inches to the height. One thing I do still want is a semi comfortable ride, I do not want a stiff ride. Is there also any other parts I should invest in when doing the leaf springs? Bolts, clamps, etc.??
Another question I have is when I replace the leaf springs how do I check if the blazer levels out? Does this mean by visually seeing if it does, or by other means?
Last question, I saw somewhere that a shackle can add height? Is this true/ what exactly is a shackle?
If this makes a difference I am replacing my currently almost decimated shocks with new Rancho RS9000XL shocks, and money is not a factor for this leaf spring project.
Thank you in advance!
-William
Old Mar 18, 2013 | 12:25 AM
95BlackGA's Avatar
95BlackGA is an unknown quantity at this point
Leafs can add height, depends on which ones you get. I'd invest in all new mounting hardware. Shackles can add lift, if you get longer shackles. You'd have to crank your torsion bars to get the front end the same height.
Old Mar 18, 2013 | 01:29 PM
bnkk's Avatar
bnkk is an unknown quantity at this point
Go with longer shackles for mild lift, they will ride better then higher arched springs
Old Mar 19, 2013 | 02:36 AM
I was possibly thinking about getting a body lift, is this a good way to add height? Or should I do a suspension life?
Old Mar 19, 2013 | 03:26 AM
Little Roober's Avatar
Little Roober is on a distinguished road
How high do you want to go? You could always do both.
Old Mar 19, 2013 | 04:19 AM
2 inch possibly 3 inch, you know any good kits? The last thing I want to do is crank the tbar up 2 inches if I don't have to.
Thank you.
89Recon
Dec 15, 2011 07:07 PM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
musclecar70sfan
27
Jan 19, 2010 04:10 PM
mr.vls
Apr 3, 2008 10:48 AM
myronhntr80
Lifting Tech
Jan 6, 2008 11:29 PM
