limited slip
Old Mar 16, 2008 | 10:03 AM
prozach1988's Avatar
prozach1988 is an unknown quantity at this point
Default limited slip
i have a gu6 rear and i was wondering how many splines my axles were and also what is my ratioso i could figure out what limited slip to get (might do this instead of just getting new spider gears) and i was looking into getting a detroit truetrac which my step brother has and i like the performance of his
Old Mar 16, 2008 | 12:34 PM
TripleBlackBlazer's Avatar
Default RE: limited slip
All Blazers from '88ish and up have 28 splines. GU6 is 3.42's. You're in the same boat as I am except my spider gears aren't stripped, just scored and slightly chipped. I don't know if you've started shopping, but be prepared for the sticker shock! New units can go for up to $400+.
EDIT: Also check out the related links below for some light reading.
Old Mar 16, 2008 | 02:38 PM
ok cool thanks for the help but the also new just spider gears go for like 200 so why not pay a little more and get something better
Old Mar 16, 2008 | 02:56 PM
WolfPack's Avatar
get a junkyard G80 from a bravada!!
Old Mar 16, 2008 | 03:08 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Get an Eaton Detroit EZ Locker.....
Old Mar 16, 2008 | 05:01 PM
If you already have an open diff with a good carrier, I would go for an aftermarket LSD or locker (depending on your preference).
Old Mar 16, 2008 | 05:28 PM
burak sozer's Avatar
burak sozer is an unknown quantity at this point
Let me tell yo uwhat I did, 4th gen Camaro LSd+ 45$ ring gear spacer from E bay ( comes with the longer bolts) , direct bolts on to old carrier with the same shims in old locations ( no need to adjust). Dont forget to add friction modifier/ limited slip additive.
Old Mar 17, 2008 | 04:17 PM
thanks for all the input but the reason i am going with the truetac is due to costs over a locker i would love a locker but i dont have the money but if i did it would be an elocker from detriot and would the axle from the bravada only be a posi
Old Mar 17, 2008 | 04:29 PM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
has anyone heard of modding the G80. I found one site that shows some mods, but I just want to know if this would be worth it. or should I get a different carrier and get a locker?
http://forums.turbobricks.com/showthread.php?t=25829
Old Mar 17, 2008 | 04:52 PM
drperry's Avatar
ORIGINAL: prozach1988
The G80 is a gov-loc style locker... If there's a (I think 200 RPM) wheel speed difference, at anything less than 20 MPH it locks up... After that the counter weights are spinning outwards, and the diff unlocks, and can't lock at highers speeds... Unless it's been modded or broken.
