lockers
Old May 8, 2009 | 09:41 PM
lil_blazin's Avatar
lil_blazin is on a distinguished road
Question lockers
Well my blazer has 10-bolts there stock for now but i want to put lockers in them. The truck is for mud and daily driving basicly so i didnt think i need to put axles and crap in it. I know what gears im going with already so the deciding factor is lockers. What lockers would you guys suggest for the front and rear?
Old May 8, 2009 | 10:46 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
wat rear end do you have in the truck now?? some blazers come with stock lockers.
Old May 8, 2009 | 11:04 PM
lil_blazin's Avatar
10-bolt half ton rear end
i couldnt tell you much more then that sorry i havent actually cracked the dif open and looked yet i know it doesnt do yeah much good
Old May 9, 2009 | 12:04 AM
mikeinwi's Avatar
well im not quite sure wat kind of blazer you have but if its an s series just look in the glove box at ur rpo codes and look for G80 thatll be the code for a factory locker, im not sure if the same code will apply for a full size blazer tho.
Old May 9, 2009 | 01:18 AM
lil_blazin's Avatar
oooohhh its a full size lolz
Old May 9, 2009 | 11:01 AM
Please put your vehicle information in your signature and attach it to your posts.
You can look on the glove box for the SPI or RPO code label (depending on year) which should detail if you have a gov-loc or lsd rear already in your truck. You could also pop the diff cover and have a look.
How much are you looking to spend on this? If you are already swapping gears, then you can go with a new diff center section. If that is the case and provided that a selectable locker is in your budget, I would go with either an ARB air locker or one of the new e-lockers from Eaton. These give you the option of unlocking the axle for around town driving and then locking it in when the going gets tough.
Old May 9, 2009 | 12:19 PM
lil_blazin's Avatar
Well ive thought about it i dont have a large budget so i guess im going to ditch one or the other gears or lockers? I would like a rear locker but i know that the blazer will be guttless without gears..
Old May 9, 2009 | 01:39 PM
What gears do you have now and what tires are you planning on putting on?
I have 3.73:1 gears with 33's on my K5 and it is no slouch going down the road.
You can put a lunchbox style locker into your open rear diff case for under $300.
Old May 9, 2009 | 02:17 PM
lil_blazin's Avatar
stock gears and 35" tires
Old May 9, 2009 | 02:45 PM
What is stock...? You could have 3.42, 3.73, or 4.10's stock. You need to figure out where you are, then figure out where you want to be.
Have you tried to drive with those tires?
