lower ball joint
Old Apr 13, 2013 | 10:08 AM
apaplayer's Avatar
apaplayer is on a distinguished road
Default lower ball joint
is it possible to change lower ball joint without removing the upper if so could some one explain please thank you
Old Apr 13, 2013 | 10:19 AM
Year, make, model, 2WD or 4WD? Are the ball joints, that need to be replaced, bolted in or riveted in?
Old Apr 13, 2013 | 10:35 AM
apaplayer's Avatar
98ls 4wd and they are bolted upper is good bottom needs replaced
Old Apr 13, 2013 | 10:59 AM
There are a ton of DIY threads here on the forum that will guide you through it. The half shaft must be seperated from the hub assembly in order to get the old joint out and the new one in. Easiest way to do that is remove the hub assembly. Then seperate the lower ball joint and outer tie rod end from the knuckle and move the knuckle and half shaft out of the way. I usually go one more step and seperate the upper ball joint and take the entire knuckle off, it gives you way more room.
Old Apr 13, 2013 | 11:08 AM
apaplayer's Avatar
thanks for the info will just go out and start pulling things off
Old Apr 13, 2013 | 11:10 AM
Not a difficult job, but it is time consuming and messy. Make sure you use a torque wrench when reassembling. If you needs torque specs, just ask.
Old Apr 13, 2013 | 12:48 PM
richphotos's Avatar
all that have to be done on first gens too? yikes LOL
Old Apr 13, 2013 | 01:24 PM
Been a while, but seems like it's very similar.
Old Apr 14, 2013 | 07:08 AM
okiedoak20's Avatar
im in the process of replacing the pass. side axle bearing and was also
looking for a simpler way of replacing the lower ball joint.... nope, i found the short cut is removing the knuckle
Old Apr 14, 2013 | 06:28 PM
apaplayer's Avatar
well been trying to get axle nuts off no luck broke 2 half inch breaker bars tried impact no luck guess it i will take to shop and have them loosen nuts
