Lower Control Arm Replacement/T-Bar Tool
Old Feb 22, 2012 | 02:09 AM
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
Default Lower Control Arm Replacement/T-Bar Tool
The driver's side lower control arm on my 2000 Jimmy needs replacing. I know in order to remove the torsion bars you need to have a special tool. In the Haynes manual, they use a puller to accomplish this instead of the special tool. Has anyone used this method before? I'll also be replacing a bad CV axle on the same side. If anyone can advise on the T-bar tool and if they have any tips on this job, I'd appreciate it.
Old Feb 22, 2012 | 02:12 AM
neo71665's Avatar
I used a 2 jaw puller, it works fine
Old Feb 24, 2012 | 11:09 PM
Alright, that's good to know. Would something like this work?: Amazon.com: Danaher Tool Group 3552 6'' 2-Jaw Gear Puller: Home Improvement
Thanks for the help.
Old Feb 24, 2012 | 11:50 PM
VortechChevyRider's Avatar
VortechChevyRider is on a distinguished road
Im new to this forum stuff, when replacing the lower control arm would be a great time to change cv axle also. With the spindle free at the bottom control arm you should be able to take the axle nut off so when the control arm is free you can seperate the constant velocity axle. Is the torsion bar referred to also as a sway bar? If so I.would advise buying a new link their relatively cheap I paid about fifteen bucks. Also look on ebay for a control arm unit with balljoint for about maybe less than eighty bucks. I also rented from autozone a balljoint or tierod end fork. Im not sure if this helpful. Pretty simple job
Old Feb 25, 2012 | 04:33 AM
chris015's Avatar
I broke a jaw puller trying to do mine. apparently those bars are under alotta weight. Ive heard by a few people ball joint press works good. C-clamps tend to bend.
Old Feb 25, 2012 | 04:58 AM
Park's Avatar
Park is on a distinguished road
No. The torsion bars have more to do with keeping the front ride height up and the sway bars fight body roll when turning. The T-bars run parallel to the frame and the sway bars run parallel to the axles.
Old Feb 25, 2012 | 10:14 AM
okiedoak20's Avatar
I purchaced a 3 piece 2 jaw puller set from harbour frieght that did the job with out and problems, the set comes with a small, medium and large 2 jaw pullers.... it was only like $15.00 bucks
Old Feb 25, 2012 | 11:08 PM
3 Piece Two-Jaw Puller Set
Something like that? I'm a little nervous to get it from HF, since it looks like all their pullers got terrible reviews. The puller from Amazon I linked to earlier was a 6". Is that big enough to do this job?
For those of you that said you've done this before, anything that I should know before starting this project? Any trick that made the job easier? I can't seem to find a how to article on this site. Thank you all for the help.
Old Feb 26, 2012 | 07:27 AM
If you sign up to autozone website they let you see all the repair info, including special tools needed, special procedures, and you can see how much it will be to rent a jaw puller and when done With the rental tool you get your money back. No need to buy a tool that you may never need, with the money you save you can put into the parts for your vehiclr.
Old Feb 26, 2012 | 12:17 PM
okiedoak20's Avatar
porkfriedrice, thats the one from HF, as far as tips and such, soak both points of the torsion bar real good with a rust breaker (PB Blaster etc)
and you will need a heavy hammer and a long rod to pound on to loosen the t-bar, the seem to get stuck with rust build up, its a simple but somewhat involving prosedure. (spelling sucks i know)
Robert
