Need help finding a lost vacuum hose
Old Nov 4, 2012 | 12:28 PM
sillyak's Avatar
sillyak is on a distinguished road
Default Need help finding a lost vacuum hose
The 4WD in my 2005 Blazer would not engage. I discovered a vacuum hose that had broken off that must be the culprit. I can't find the hose that plugs into this nipple though. You would think it would be hanging loose right below where it broke, but it is not. Can someone tell me what the other end of this hose links up to so I can follow it back? Here are two pictures for clarity:
Old Nov 4, 2012 | 02:02 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Did it break or just come unhooked?
Im going to take a guess and say it came of the actuator on top of the Tcase.Good luck with it.
Old Nov 4, 2012 | 03:11 PM
sillyak's Avatar
It broke, but right at the nipple.
Old Nov 4, 2012 | 04:12 PM
sillyak's Avatar
Fixed it. The actuator on the 4-button 4WD models is under the battery. Took off the battery and the platform it's on and found the actuator. Traced the vacuum line back, it had fallen behind and below the distributor box when it broke. Problem solved.
er0ck273
May 21, 2013 06:31 AM
86TransAm
14
Dec 13, 2011 07:46 PM
fahli
Mar 1, 2011 06:38 AM
GotYoNacho
14
Feb 17, 2010 10:29 PM
rob1621
Apr 3, 2008 08:55 PM
