Newbie question about 4WD
Old Jan 31, 2010 | 06:14 PM
gil's Avatar
gil
gil is on a distinguished road
Default Newbie question about 4WD
Hi All,
Blazer with 4button switch! (NV236 t-case)
If I am in 2HI and engage the front axel(manualy with posi-lok type cable) do I now have 4HI? If not what is the difference between 2HI and 4 HI?
Thanx
Gil
Old Jan 31, 2010 | 06:17 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i dont know what it would be considered
For 4 wheel drive high, press the 4Hi button, then pull the locking cable handle firmly and twist it to lock it in place. To return to 2 wheel drive high, press the 2Hi button, the twist the locking cable handle and push it in and twist once again to lock it in place.
For 4 wheel drive low, press the 4Lo button, then pull the locking cable handle firmly and twist it to lock it in place. To return to 2 wheel drive high, press the 2Hi button, the twist the locking cable handle and push it in and twist once again to lock it in place.
For 2 wheel drive low (used for moving trailers around at slow speeds when tight cornering is needed), put the transmission in neutral and press the 4Lo button. Do NOT pull the locking cable handle.
-myson
Old Jan 31, 2010 | 06:43 PM
With the NV236 transfer case, it may not like having the front axle disengaged when in any 4wd mode.
As far as the question that was asked, to get into 4wd, you must have both the front axle engaged as well as the transfer case in one of the 4wd modes (auto4wd, 4hi, or 4lo).
By locking in the front axle while in 2HI, all you have done is increased the rotational inertia of the drivetrain which will decrease your fuel mileage. Without the transfer case engaged in one of the 4wd modes, you are not in 4wd.
Old Jan 31, 2010 | 07:30 PM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
-myson
That's confusing.... Well not really, but still that's a lot of work. I like my floor shifter
Old Jan 31, 2010 | 08:05 PM
ImScrewed92's Avatar
X2 on that one. Even though with the body lift I can barley grab it to shift it, I still like it. Although I would like to go to a manual lock system so as not to worry about the vac. system.
But then agian I would love to go to solid front and ditch the cv's, boots and all that lovely crap, but oh well.
Philipx
Nov 3, 2011 10:36 PM
TylerK10
Sep 22, 2011 10:31 PM
Jennifer
Sep 20, 2008 09:23 AM
Newfiezedder
May 13, 2006 05:42 PM
Gunner Woody
Feb 13, 2006 04:41 PM
