no 4hi
Old Jan 30, 2010 | 06:21 PM
strotter's Avatar
strotter is on a distinguished road
Default no 4hi
I have an 04 4wd blazer with the three push buttons in the dash 2wd works fine so does 4Lo but when i push the 4hi button the 4hi and low buttons just flash and the truck goes back into 2wd what could this be thanks for your help
Old Jan 30, 2010 | 06:53 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
actuator/motor
its one part, check your vacuum lines are not dry rotted. also in the manual there is a way to make it go into 4wd hi. cant remember how you do it. (its different then just pushing the button, its a sequence). its in the section about 4wd.
Old Jan 30, 2010 | 06:58 PM
Blazerkid19's Avatar
Blazerkid19 is on a distinguished road
yea i noticed today (of all days) that i dont have 4hi. i have 4lo but that dosent help gettin down the road with 6in of snow. i can hear the transfer case shift when i push the button but what the crap. also i have a posi lock system to engage my front diff. and i know its good.
Old Jan 30, 2010 | 07:02 PM
Banned
"posi lock-is the locking of both front tires to spin at the same time. also known as a front differential. if your blazer is stock it doesn not have "posi lock". are you talking the diu posi-lock cable setup, with the write up on here?
Old Jan 30, 2010 | 09:53 PM
strotter's Avatar
ok will do some checking in the morning
Old Jan 30, 2010 | 09:55 PM
Banned
the actuators/motors are a pretty common failure, although i've seen a handfull of vac leaks cause this
Old Jan 31, 2010 | 10:53 AM
strotter's Avatar
i got it working unhooked the battery for 30 minutes and then hooked it back up works great but now my speedometer is pegged out at 100 any suggestions on how to fix this
Old Jan 31, 2010 | 01:22 PM
Banned
try ressetting your computer by taking the battery cable off again for 30 minutes. then rock it back and forth between drive and reverse. after you've hooked the cable back up and the trucks on
Daninehnj
Mar 9, 2007 11:48 AM
Josiemikzoo
Dec 5, 2006 02:17 PM
DaveInDaytona
Jan 6, 2006 11:19 PM
hamoni1
Dec 6, 2005 07:39 PM
tambo
Mar 4, 2005 05:44 PM
