NOISE!! haha
Old Aug 15, 2009 | 06:49 AM
They probably installed a $1 conical washer (Hood Hinge Rattle - TSB 01-08-63-001B).
Glad you got it fixed!
Old Aug 15, 2009 | 11:20 PM
kiwiblazer's Avatar
Hey Kyle! Just checked my bonnet (hood). I can actually move it up & down at the pivot bolts. More so on the left than the driver side. Not much, but sufficient to create the rattle I'm sure. I'll look into this conical washer thing you refer to. Is that it's part no. quoted on the TSB? Or will any spring washer do the trick?
I was surprised to see it's only held with a 3/8" (I think) bolt.
Man, where would I be without your infinite wisdom?
Probably at the mercy of the local mechanics (my dad used to refer to them as Ali Baba & his 40 thieves!) LOL
Old Aug 26, 2009 | 02:01 AM
kiwiblazer's Avatar
Hey Kyle! You were bang on the money with the hood rattle.
When I took my truck in to get the a/c & heater sorted I gave the Chevy guys (who were still scratching their heads over this rattle), a print of the TSB.
Whilst they had it, they fitted the washer on the hood & now I have a surprisingly quiet ride every day.
I think they now have respect for this forum. I see they had been checking it out!
Thanks again Kyle 'o wise one! I salute you!
Old Aug 26, 2009 | 08:20 AM
Glad you got it fixed Ken! That noise can cause a LOT of unnecessary repairs if it is not checked first. It sounds so similar to bad sway bar end links as well as bad ball joints.
Sorry I did not respond sooner. I was on vacation last week and did not have cell service, let alone internet!
Old Nov 23, 2009 | 08:10 PM
SWC1969's Avatar
SWC1969 is on a distinguished road
Thanks for the hood hinge tip...I had the same issue!
Another noise that I found in my quest for this rattle was at the right front sway bar end link. For some reason, the right end of the sway bar sits closer to the control arm than the left side does (This isn't the only Jimmy I've seen this on). This causes the end link to be pushed back and wear out the inside of the upper bushings, which then allows the center bolt to make contact with the control arm bracket.
Old Nov 29, 2009 | 07:50 AM
Theordkid's Avatar
Theordkid is on a distinguished road
Default help
I am happy to find this forum .. i have a 99 blazer .. I have hood hinge noise .. my question is where does the conical washer fit ? bolt side ? between hood hinges ? nut side ? thanks for any help you can lend me !
Old Dec 3, 2009 | 07:02 PM
SWC1969's Avatar
Bolt side.
Old Dec 3, 2009 | 07:06 PM
SWC1969's Avatar
I actually fixed mine by inserting a short piece of vacuum hose in the rubber bumper that sits at the top of the fender and the hood rests on it when it's closed. This put enough upward pressure on the hood to keep the hinge from rattling.
88s10Blazer
Dec 22, 2009 02:12 PM
sledneck16
Oct 15, 2008 10:26 AM
Blazin_1t_up
Tires and Wheels
Sep 8, 2008 11:02 PM
blazinrebel
May 2, 2008 08:40 PM
Bgray
Jan 24, 2006 08:05 PM
