Noise in read end 1995 blazer 4x4
Old Jan 1, 2012 | 10:33 AM
Hairball's Avatar
Hairball is on a distinguished road
Default Noise in read end 1995 blazer 4x4
1995 blazer 4x4. Had a broken brake line when I bought it. Got that fixed but it makes a noise, It is either in the rear end or the brake, I am not sure I got it bled good enough, kind of makes a whoomp whoomp whoomp sound going down the road. I had a 71 torino that did the same thing, Just wondering if anyone had same problem
Old Jan 1, 2012 | 10:56 AM
By the description of the noise, I would take a guess that you have a wheel bearing going out on you.
Old Jan 1, 2012 | 05:04 PM
jimhens82's Avatar
jimhens82 is on a distinguished road
or a bad tire
Old Jan 1, 2012 | 08:15 PM
Hairball's Avatar
I will try the bearing thing, one person replied about a bad tire. Ok one thing about that is I can not get that tire off for anything, I have tried everything but driving it with the lug nuts a little loose and hoping it breaks it off the rim. I have had all lug nuts off and kicked and used a 3 pound sledge on the back trying to get that tire off and no success, it has stock alunimun wheels on it,
Old Jan 2, 2012 | 11:07 AM
richphotos's Avatar
have you used any penetrating oil? this happened on my 94, sprayed a bit on, let it sit and wiggled it off. once it was off, going off and on after was fine
Old Jan 2, 2012 | 11:30 AM
jimhens82's Avatar
im an auto tech, ive seen many wheels seized to the hub...either a big azz pry bar or swingin your hammer like a bat lol, pops off everytime
Old Jan 3, 2012 | 04:21 AM
Hairball's Avatar
i have tried wd40 on it. I might just have to try a little harder, I have pancreantitis and makes it a little hard to swing., In hospital right while we speak, Been in a week so far . Spent most of 2011 in hospital. Soon as I get out I will try it again. I will call my wife today and have her spray inside the hub more, Thanks guys, any help is appreciated
Old Feb 12, 2012 | 04:22 AM
ultanium's Avatar
ultanium is on a distinguished road
Definitely sounds like wheel bearing, hope you get better and are able to get the wheel off. Had a Bimmer I couldn't get a wheel off of, took it to Discount Tire and they got it off for free.
Tom
Old Apr 7, 2012 | 11:12 PM
Aquarian Devil's Avatar
Aquarian Devil is on a distinguished road
Also might be the pinion gear missing some teeth? When was the last time the gear oil was changed? Wouldn't hurt to pull off the inspection cover and see what the rear end looks like. 2 quarts of gear oil, new gasket and a tube of RTV will run you less than 20 bucks.
Old Apr 8, 2012 | 09:12 AM
Hairball's Avatar
Thanks Devil I will try anything. Wife likes to drive this thing all the time,
kevinph
Feb 25, 2019 09:24 PM
Doug Fields
Aug 26, 2013 10:15 AM
opposedforces
Sep 1, 2011 02:59 PM
BaLListic_Evo
Jun 4, 2010 03:38 PM
xckid
Oct 15, 2008 05:58 PM
