noise in reverse only
Old Apr 17, 2013 | 06:31 PM
jayj99jimmy's Avatar
jayj99jimmy is on a distinguished road
Default noise in reverse only
I have a 1999 gmc jimmy 2door SL 4wd. It has 108k miles. within the last 3k miles I have noticed that when I am reversing out of say, a parking spot, it will squeak, like a eeee ooo eee ooo eee ooo... best I can do on here lol. but basically its not a steady pitch, it goes up and down. I have replaced my ebrake shoes, brake pads, rotors, and have greased the pad guides with silicone brake pad grease. the noise has not changed at all. I can try and put a video on youtube of this noise and add a link when I get time. Anyone have any ideas what else could make a squeak, from the rear, only in reverse if its not the brakes? the squeak gets much more pronounced and apparent when I push on the gas in reverse as opposed to just rolling in reverse, however it never actually goes away. so, as I push the gas, the rear end of the vehicle lifts up due to torque and I start moving and the squeak is significantly more obvious, once I let off the gas it is still there but about half as loud.
any ideas on where to check next would be greatly appreciated.
Old Apr 18, 2013 | 11:24 AM
okay I made a video of the noise that my truck is making, it's not the best, but its all I have. This noise only happens when I'm in Reverse. It gets louder when I'm giving it gas but when I start coasting in Reverse its a lot quieter but it never goes away. I thought it was my brakes, but I've installed new emergency brake shoes as well as brake pads and rotors I've cleaned my calipers and properly greased them. now I am clueless of what to check next
any tips or information would be greatly appreciated
Old Apr 18, 2013 | 12:23 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
I think it would be your U-Joints. Mine made the same exact noise when they were seizing up. I would replace those if I were you, I bet the sound will stop!
Old Apr 18, 2013 | 05:39 PM
i will check them out. i think i remember using and automotive stethoscope to listen to the ujoint while it was on jackstands with the transmission in reverse. i felt like the noise was coming from near the wheels, but maybe i overlooked something. is it possible that i could spray some grease or something on the ujoint while its spinning to see if the noise changes?
Old Apr 18, 2013 | 06:00 PM
well i just sprayed some lithium grease all over the ujoints and the noise is gone. sounds like they are bad. i will look into replacing them and post back here. thanks alot for the tip im sure this will fix it!
Old Apr 19, 2013 | 10:45 AM
Jakeduece's Avatar
Awesome, I'm glad you got it narrowed down. If they are factory joints, you will need a good propane/map torch to heat them up, gm injected nylon to hold them in. Took me 2 hours to replace my factory joints. I tell you what though, you will notice a difference when you are done!
dj00140
Apr 13, 2011 10:40 AM
wcolclou
Nov 3, 2010 08:23 PM
1986k5blazer
May 26, 2009 06:54 PM
HHimmy
Mar 31, 2009 08:38 PM
Nuzman
Jun 7, 2008 11:37 PM
