is this normal?
Old Feb 15, 2013 | 11:54 AM
brian400ex's Avatar
brian400ex is on a distinguished road
Default is this normal?
I have a 2003 blazer with 48000 miles on it. While greasing the pitman arm I notice grease causes arm to move by the castle nut. Normal?
Old Feb 15, 2013 | 01:20 PM
Twip's Avatar
move in which way?? up and down like vertically or side to side like it would be steering?
Old Feb 15, 2013 | 01:35 PM
brian400ex's Avatar
Vertically. Grease pushes it
Old Feb 15, 2013 | 01:49 PM
Diaita's Avatar
Um, no. Is the nut loose?
Old Feb 15, 2013 | 02:19 PM
brian400ex's Avatar
Idk. It hasn't been touched from the factory. Cotter pin is still in. Should i tighten it? How tight do u go?
Old Feb 15, 2013 | 02:47 PM
brian400ex's Avatar
Should it have a rubber boot that fills up with grease?
Old Feb 15, 2013 | 04:15 PM
newguy's Avatar
Is there play in the tire on that side? Jack that side up and grab the sides of the tire and wiggle back and forth and check for play. It may be bad or it may just need tightening
Old Feb 15, 2013 | 04:21 PM
Not normal, there should never be vertical movement in the joint. If it's 2WD the center link needs replacement. If it's 4WD the pitman arm needs replacement.
Old Feb 15, 2013 | 06:23 PM
brian400ex's Avatar
I used a pry bar and I couldn't get it to move.
Old Feb 15, 2013 | 06:26 PM
But the grease gun made it move????? Shouldn't be any movement, ever.
