NP233 shaft
Old May 30, 2010 | 01:14 PM
cyberdog's Avatar
cyberdog is on a distinguished road
Default NP233 shaft
I have a 1996 Blazer with the 3 button TC, belive its called np233. The splines on the front output shaft on the TC and axle have gone bad so need to buy new and replace. Where can i buy those parts ?
Thx. Pete
Old May 31, 2010 | 12:46 PM
cyberdog's Avatar
Click on the pic for bigger pic Where can i buy that part aswell as the front output shaft on the TC ?
What is that part called that i have boxed in with red ?
Old May 31, 2010 | 01:38 PM
That is part of the front driveshaft. Get a new driveshaft and it will mate right up to your transfer case.
As far as where to get the front output shaft, you will likely want to look around junkyards for the part. This isn't a typical replacement part and many places that sell rebuild kits are likely to refer to the dealer ($$$).
Old Jun 8, 2010 | 08:50 AM
cyberdog's Avatar
Well that sucks if i cant find a new front outoput shaft. Most likely no salvage yard here in Sweden has that part laying around. WOuld be if i found some in a US yard and got it sent here.
Other idea would be to remove the shaft and have it welded and then make new splines on it.
Old Jun 8, 2010 | 11:47 AM
You could try contacting the eBay seller s10warehouse to see if he could part one for you.
Old Jun 9, 2010 | 02:07 PM
cyberdog's Avatar
I found the shaft by mailing drivetrain.com Will order the shaft, output shaft bearing , seal and also the chain. Will change the chain since i am opening up the TC anyways
Thx for the help anyways.
Old Jun 9, 2010 | 05:56 PM
That was the first place I looked, but they didn't show the output shaft in their table. Glad you found it.
Old Jun 12, 2010 | 02:45 PM
cyberdog's Avatar
Going to buy a used front driveshaft but need to know which ones fits my car. I have the 2dr Blazer and i guess the shaft from the 4dr is too long or is it the same ? Which years shafts fits my 1996 ?
Also is there a place that sells just the part that goes to the front output shaft on the TC or do i have to buy a complete driveshaft ?
Thx.
Old Jun 18, 2010 | 09:22 AM
cyberdog's Avatar
Anyone ?
toyblazervt
Nov 28, 2010 05:07 PM
kevinae86
Aug 12, 2010 11:30 AM
JamesC
Nov 23, 2009 08:32 PM
mandng0
Apr 30, 2009 07:10 AM
Mikeshonda750f
Dec 7, 2008 12:01 AM
