NP233 Transfer Case Rear Spline Count Question
Hello Forum,
I am in the process of getting a Transfer Case for my Blazer My question is if you have the Identification code tag info that is on your Transfer case. Model No. Assembly No. Serial No. Gear Ratio Can you tell how many output splines you have in the rear? I have noticed that the NP233 remanufactured Transfer Case can come with different combinations of 27 or 32 Spline Counts. Front Spline Count 27 - Rear Spline Count 27 Front Spline Count 27 - Rea Spline Count 32 Can you tell with the Transfer Identification Tag info what the Spline Count is on the rear. I think from what I have found is that the front input is always 27 on the NP233 but the rear Spline Count can be 27 or 32. Not sure what decides or how you know what the rear count is or should be besides physically counting them. Thanks for any info. Mark K |
For anyone interested,
I think I found out my answer. Some of the 92 and 93 Blazers came with a NP233C Transfer case also. For some reason not all but some have a 27 Spline Output shaft. Not sure if you were to look at the metal tag on the Transfer case if you could figure that out. So beware if you pick one up from the salvage yard. Not all NP233C are the same. A small minority could have a 27 rear output spline. Best to know what year it came out to be on the safe side. Original Transfer cases from 1994 and on would have a 32 rear spline output shaft. Here is a parts list for those interested from DriveTrain. Great website. They have everything. http://www.drivetrain.com/parts_cata...33encodermotor Mark K |
