The odd noise???
Old Sep 3, 2008 | 02:48 PM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default The odd noise???
I cannot pinpoint this problem at all. My 2004 blazer has began to have a very weird feel when im braking. it almost feels like a slight grinding but there is no grinding noise etc.. Also when driving up at speed there is an odd vibration feeling on the passenger side. And i cannot figure this out.
At one point it was making this weird vibration noise feel when i was turning right??
Any ideas
Thanks gueys.
Old Sep 3, 2008 | 06:29 PM
Default RE: The odd noise???
Sounds as though it could be the beginning of a wheel bearing failure, but your "odd vibration feeling" on the right (passenger) side does not agree with your "weird vibration noise feel" while turning right which may indicate a driver side wheel bearing problem.
Old Sep 3, 2008 | 09:03 PM
WolfPack's Avatar
Both bearings dying, passenger side closer to failure?!
Old Sep 3, 2008 | 09:05 PM
Its possible.
Old Sep 3, 2008 | 10:50 PM
jman_08's Avatar
Its almost like a thumping feeling in the passenger side but these tires have some very weird patches in them as well i bought the truck like that maybe new tires wouldnt hurt.
Old Sep 4, 2008 | 06:02 AM
If the tires are worn weird, it can cause issues like this. Maybe try rotating the tires front to back and see if the problem follows the tires.
Old Sep 4, 2008 | 11:43 AM
jman_08's Avatar
As i was pulling into a parking spot today i put on the brakes and felt that grinding i also heard a noise like when i semi slows down the wind down noise the semi make when they slow down if u know what im talking about what is this problem????
Old Sep 4, 2008 | 07:04 PM
WolfPack's Avatar
sounds like tire wear. That's how I know when I need to rotate my AT2s (the front wears in a forward slopped pattern...a/t tires )...I get a 'grind' and loud noise as I slow down...after rotating the tires, problem solved.
Old Sep 5, 2008 | 12:12 PM
WFD28's Avatar
WFD28 is an unknown quantity at this point
Does your truck have torsion bar suspension out front?....if so does it make a clunking noise while you feel that on the passenger side?
Old Sep 17, 2008 | 11:23 PM
watsonmt's Avatar
watsonmt is an unknown quantity at this point
mine has t bars up front and i get a clucking noise in the passenger side... what the hell is it i cant figure it out...please help...
Thanks matt
