options
Old Aug 28, 2008 | 09:12 AM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
Default options
i was reading on the web that the blazer was offered with seven suspension packages. so i was wondering how to find out what mine is. and what the difference in them were.
thank
Old Aug 28, 2008 | 09:25 AM
Default RE: options
Mainly shock differences, but some were heavier for towing, some heavier sway bars or simply the inclusion of the rear sway bar. There is very little information on the different packages, but if you could track down a sales brochure, it should have some of that information in it.
You can find your suspension package by decoding the RPO codes located on the label inside your glove box.
Old Aug 28, 2008 | 11:12 AM
Default RE: options
ok thanks. i will do that. but i looked at my shocks and they are the "de carbon" . i am needing new ones but i dont have the money.
Old Aug 28, 2008 | 12:38 PM
Default RE: options
i checked my rpo codes and it said i have the premium smooth ride suspension package. is that a good one.
and i also checked some of my other codes and it says that my rear axle has a 3.42 ratio. my generator is 100 amp. my GVW is 5350. and is says i have
L35 ENGINE , "GAS, 6 CYL, 4.3L, CPI, V6, 90 DEG, HO" is that different from normal?.
Old Aug 28, 2008 | 12:41 PM
Default RE: options
CPI is wrong as it is the SCFI motor. CPI was the earlier 4.3L used until 95.
About the suspension... Don't know. That is what my old Bravada had.
Old Aug 28, 2008 | 12:53 PM
Default RE: options
well i used a rpo checker from an s10 site. i just copied and pasted. but my blazer is a 98.and i also read on Wikipedia that there was a
1996-2005 - 4.3L Vortec 4300 V6, CSFI, 195hp (130kW)/250ft·lbf (332N·m) (VIN W)
and
1996-1999 - 4.3L Vortec 4300 V6, CSFI, 170hp (134kW)/240ft·lbf (325N·m) (VIN X)
what would have been the purpose of the 2 engines? and what would have put one in a blazer. what was there application?
Old Aug 28, 2008 | 01:40 PM
Default RE: options
Only difference between the two was programming. The vin X was never offered in the Blazer.
sgray84
Sep 6, 2006 12:57 PM
rcravincase
Engine & Internal
Jul 5, 2006 08:14 AM
djbass_mekanik
Suspension Tech
Feb 9, 2006 03:17 AM
ajmeehan
Engine & Internal
May 23, 2005 11:41 PM
Hypersona
Dec 15, 2004 08:56 PM
