pitman arm?
Old Oct 24, 2010 | 01:35 AM
mov4x4's Avatar
mov4x4 is on a distinguished road
Question pitman arm?
Alright I would like some opinions on the pitman arm because I'm haveing to replace mine should I go ahead and buy an upgrade/more expensive one or just buy the oem replacement? Just a stock 4x4 s10 blazer no lift
Old Oct 24, 2010 | 12:00 PM
Jimbotopotomous's Avatar
Jimbotopotomous is on a distinguished road
I just re-did the front end of my jimmy, replacing all 4 ***** joints, tie-rods, and idler arm. The kit i bought also came with a pitman arm but i did not replace mine because you have to take out the steering box to change it, and the stock one that's been in there for almost 170k miles was still working fine, so i would say just stick with OEM and it will hold up just fine, most likely for the rest of your truck's life. Just make sure to grease the replacement well and it should never give you any problems.
Old Nov 1, 2010 | 01:16 AM
TriBlaKer's Avatar
TriBlaKer is on a distinguished road
Where'd you get this kit? I'm having to do the same with mine and buying in bulk would be a LOT easier, I'm needing to replace ball joints tie rods idler arm pitman arm and i think there was one more arm??
Old Nov 1, 2010 | 01:24 AM
mov4x4's Avatar
I'm not sure I sold my 94 and bought this 95 with 130k miles and the old owner put new ball joints and idler arm on it and I did the tie rod ends and still have to put the pitman arm on went with the oem and it was like $22
And I'm probably putting it on this weekend and also getting it aligned but it needs the pitman arm bad there's a good quarter to one third turn in the steering before the tires start to turn. Its bad
Last edited by swartlkk; Nov 1, 2010 at 04:57 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 1, 2010 | 02:02 PM
TriBlaKer's Avatar
Yup same here
Old Nov 2, 2010 | 11:42 PM
abig84's Avatar
removing the gear box really isnt such a pain. ive been doing alot of these at work. access to a impact is a must though. you just take the three bolts off holding it to the frame, leave everything else connected except the pitman arm ball joint of course. then spin it sideways so you can get at the bolt then put the puller on it and impact away. BUT as was said if the pitman arm is fine. leave it the heck alone. ive seen where they wouldnt come off so easy
Old Nov 3, 2010 | 12:02 AM
mov4x4's Avatar
I know for sure mine needs replaced
Old Nov 7, 2010 | 01:16 AM
ZR2HEAD's Avatar
ZR2HEAD is on a distinguished road
Hi Jimbotopotomous,
Can you tell me who made your kit and is it good quality, if so where did you purchase it, I need the same for my 2001 ZR2
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
