Pitman Arm Help
Old Apr 23, 2011 | 07:30 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Pitman Arm Help
Does anyone know the size of the nut holding the pitman arm to the steering gear shaft and can you remove it without pulling out the steering gear? Thanks.
Old Apr 23, 2011 | 08:44 PM
TMM217's Avatar
TMM217 is on a distinguished road
i dont think u can get a puller tool in there and the pitman arm probably wont just slide off
Old Apr 24, 2011 | 02:23 AM
How much of a pain is it to pull out the steering gear? That's all I have left before installing all my new parts.
Old Apr 24, 2011 | 09:01 AM
chris015's Avatar
lol ive been holding mine off for the same reason. Talked to a mechanic and he said its not bad. takes about 2 hours to finish. Id rather just pay the $100 labor and have him do it. Its not too hard,just the bolts and the lines for the powersteering.
Old Apr 24, 2011 | 09:51 AM
Over the past few days I've gotten my ball joints, idler arm and tie rods out and I need the tie rods in to start torquing everything in. I don't have a wrench big enough to get that nut off the steering gear shaft so if anyone knows the size of it, it would be extremely helpful. Thanks guys. Btw..i already tried . Out of all the videos i've seen, blazers and jimmys are the worst for getting the p arm out. There's very little room in there to work with.
Old Apr 24, 2011 | 10:33 AM
atvwarrior's Avatar
atvwarrior will become famous soon enough
I did mine in about 45 minutes there easy , take the three bolts out of the steering gear (that go through the frame) , and the one bolt holding the steering shaft to the steering gear and then the lines and the nut holding it to the center link . Then I put my hole steering gear in a vise and used a pitman arm puller with the impact . I had to do it twice because the first time advance gave me the wrong part , but at least the second time I knew how to do it .
Old Apr 25, 2011 | 11:55 PM
I ended up taking out the steering box as suggested/necessary and have it almost back to installed. Still need to connect the second steering fluid hose. After many, many hours, I'm finally to the "installation" stage instead of "demolition.' I cant wait to get her back on the road.
Old May 11, 2011 | 04:03 PM
Loose's Avatar
Loose is on a distinguished road
no one answered the first question which was what size is the nut holding the arm to the steering box
Old May 30, 2011 | 08:28 PM
JMLaux's Avatar
JMLaux is an unknown quantity at this point
On my 96 4x4 blazer it is a 33mm nut on the end of the pitman arm
Old May 30, 2011 | 10:03 PM
I ended up just using a large adjustable wrench and made sure it was really tight. I stayed up all night to work on it so hardware stores were all closed.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
