Pitman and Idler arm replacement
I plan on replacing both of these this weekend. What tools will I need to do this?
A pitman arm puller would make things easier, but you have to pull the steering gear box loose to be able to get one on.
yeah i know i have to pull the gear box. Is that the only tool i should need?
A 1/2" drive socket set, wrench set, mallat, ball peen hammer, and a pickle-fork. I believe thats what I used last time.
Yeah you will really want an impact hammer with a lot of torque for the pitman arm
True true-if you don't have access to air tools, you can get a cheater pipe to help.
You can also get a tierod end press to aid in the removal of the tapered rod ends at both the pitman arm and the idler arm where they connect to the center link. But a pickle fork works good too. Even better is a pickle fork air hammer bit!
Now we"re talkin! Get some!
I removed my steering box right out of the truck and used a 3-jaw puller and my electric impact to get the pitman arm off. Took about 10 minutes to get the steering box out and 5 to remove the pitman arm. Just throwing out other options depending on what tools you have! BFH is certainly a must:)
I was at autozone today and saw that pitman arm puller. We have those in our snap-on puller kits. I've always just grabbed whatever puller fits the job needed! lol, oh well. Learn something new everyday.
| All times are GMT -5. The time now is 07:36 AM. |
