Please help - 2000 4-button stuck in 4LO
Old Dec 8, 2010 | 09:48 AM
Shelby's Avatar
Shelby is on a distinguished road
Default Please help - 2000 4-button stuck in 4LO
Have a 2000 blazer stuck in 4low 4 way switch on dash. Turned it on it was in 4 low. It won't get out. bought new dash switch,shift motor tore trasfer case apart several times and still can't figure it out. PLEASE HELP running out of wit and money.....
Last edited by Shelby; Dec 8, 2010 at 09:51 AM. Reason: should be in posting for help
Old Dec 8, 2010 | 10:29 AM
zedartwo's Avatar
I'm not being an ***. Just people overlook the small things. Did you try neutral and shifting. Mine will ONLY shift if in neutral. Not park, and only 4lo. Everything else is on the fly.
Good Luck.
Old Dec 8, 2010 | 10:31 AM
*Moved to a new thread instead of part of another thread*
Have you tried manually shifting the transfer case into 2HI? You will need to take off the encoder motor and move the sector shaft manually. 4LO is at one extent of rotation and 2HI should be at the other extent.
I haven't done this to a NV236 (4-button) transfer case, but I know on the NV233/NV231, the sector shaft only rotates about 60 degrees clockwise to get from 2HI to 4LO with 4HI at 20 degrees clockwise from 2HI and neutral at 40 degree clockwise from neutral.
Old Jan 11, 2011 | 10:27 AM
sfazio9's Avatar
sfazio9 is an unknown quantity at this point
Default Stuck in 4 wheel
I had a similar problem that corrected itself by disconnecting the negative battery terminal. It may have reset the computer. I was stuck in 4 wheel high for a while and after trying this things went back to normal. I have a 2000 S-10 Blazer.
Old Feb 25, 2011 | 07:42 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Did you find out what the problem was , I'm also stuck in 4 low . It trys to go into 4 high but grinds for a quick second then goes to 4 low again . Thats while I'm shift from reverse to neutral .
762mm
17
Nov 21, 2024 11:36 AM
Flyfishen
Jun 18, 2019 11:22 AM
ejp
Jan 4, 2009 02:47 PM
Alterac
Aug 25, 2008 08:48 PM
FImports
May 30, 2007 09:57 PM
