popping noise in front passanger side
i have a 97 s10 blazer i just replaced the upper and lower ball joints..inner and outer tie rods..both cv axles and the axle seals. Now when i get in my truck and put it in reverse and turn the wheel to the left and back up it makes a loud popping noise and i can't find whats causeing it. Any help would be nice thanks in advance guys
bushings
could be upper and lower A arm bushings worn out or the tie rod ends on backwards touching the inside of the rim...
Originally Posted by jkyle187
(Post 650301)
I have a 2001 4.3 4wd and I have a noise that occurs when backing then braking. To me it sounds like metal hitting metal. Investigation sounds like I have a torsion bar problem. The vehicle bounces around like shocks are gone. The front end is elevated and the rear is nearly bottomed out. This has occurred suddenly and I can't identify a cause. Not sure about the resolution.
Originally Posted by 2001s10driver
(Post 650841)
