popping noise in front passanger side
Old Jun 1, 2015 | 06:35 PM
pacecountryboy's Avatar
pacecountryboy is on a distinguished road
Default popping noise in front passanger side
i have a 97 s10 blazer i just replaced the upper and lower ball joints..inner and outer tie rods..both cv axles and the axle seals. Now when i get in my truck and put it in reverse and turn the wheel to the left and back up it makes a loud popping noise and i can't find whats causeing it. Any help would be nice thanks in advance guys
Old Jun 1, 2015 | 11:15 PM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
Default bushings
could be upper and lower A arm bushings worn out or the tie rod ends on backwards touching the inside of the rim...
Old Jun 1, 2015 | 11:45 PM
I plan on putting the moog control arm bushings on it next week when I get paid and the the tie rods went back on the way they came off
Old Jun 11, 2015 | 11:17 PM
2001s10driver's Avatar
2001s10driver is on a distinguished road
I have a 2001 4.3 4wd and I have a noise that occurs when backing then braking. To me it sounds like metal hitting metal. Investigation sounds like I have a torsion bar problem. The vehicle bounces around like shocks are gone. The front end is elevated and the rear is nearly bottomed out. This has occurred suddenly and I can't identify a cause. Not sure about the resolution.
Old Jun 11, 2015 | 11:43 PM
Mine started after I replaced all my front end parts..it sounds like metal on metal but I thank mine is the upper control arm popping iam replaceing the bushings in them and I will let u know it fixes it
bam_9_9_9
24
Dec 28, 2010 07:58 PM
gizmo_587
Feb 22, 2010 11:32 PM
sschuler
Jan 5, 2009 03:43 AM
sasquatchfound
Jun 19, 2008 12:45 PM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
