Popping Noise from Rear End
Old Mar 15, 2008 | 01:01 AM
bigt7088's Avatar
bigt7088 is an unknown quantity at this point
Default Popping Noise from Rear End
I have a 2000 4wd blazer. Before a mudding trip, a 6'8 400 pound gorilla(my buddy) decided to act stupid and bounced up anddown hanging off the back. When he did that, I felt the shocks "bottom out". I didn't notice anything wrong untill we got to the bumpy roads and I hear a popping noise from theleft rear when it bounces. Does this mean I'm going to need to replace that shock?
Old Mar 15, 2008 | 08:14 AM
Default RE: Popping Noise from Rear End
I believe that you should bottom out on the bump stops in the rear before you bottom out on the shocks themselves.
Does your truck have a rear sway bar? It is possible that an end link has gone bad.
But it is possible that your shocks could have been damaged... You just need to get back there and check everything out.
Old Mar 17, 2008 | 10:31 AM
bigt7088's Avatar
I haven't had much time to look/work on it yet. But by glance inspection, I see that the lowest leaf in the leaf spring on that particuclar sideis completely flat. And by the way, I didn't find a rear sway bar.I plan on taking care of this issue as soon asI can, but do you think this is responsible for the popping noise? Thanks!
Old Mar 17, 2008 | 10:45 AM
The last spring (lowest) on a leaf spring package is typically flat in a truck platform. It is an overload spring.
And no, I don't think that the lack of a rear sway bar has anything to do with the problem you are experiencing.
Old Mar 19, 2008 | 08:00 PM
Dturner14's Avatar
Dturner14 is an unknown quantity at this point
I might woud start by seeing in the shock/shocks are leaking in anyway. how old are the shocks? as far as the leak spring they have the flat look but look around them, clean them off and look for any cracks that might be in them. Also just wondering if it could be the exhuast hitting something or loose? thats about all I can say to help, hope everything goes ok for you and you fine that problem. Tell your buddy to go bounce on someone else car, LOL
Markolc
Mar 21, 2015 06:15 PM
mjink.11
Mar 18, 2013 10:32 AM
bam_9_9_9
24
Dec 28, 2010 07:58 PM
sschuler
Jan 5, 2009 03:43 AM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
