Is it possible to replace power steering lines on 94 s10 chevy blazer engine W?
Old Jun 16, 2015 | 07:38 AM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default Is it possible to replace power steering lines on 94 s10 chevy blazer engine W?
I've never dealt with the power steering on my truck and it's leaking pretty bad and I am tired of it finally so I am wondering if you have to pull the entire pump to replace leaky pressure lines for my steering pump or if there is an easy fix involving clamps and a new hose. It looks like the lines are not removable on one end but I have no idea, could someone please steer me in the right direction, it's about time I fix this.
Just checked autozone online and it looks like they sell the parts to replace the pressure and return hose, how difficult is it to get at the fittings on the pump?
Old Jun 16, 2015 | 09:11 AM
burned's Avatar
burned is on a distinguished road
Its most likely the high pressure line that is leaking.
Real easy job to remove the hose and replace. Take off the line at the steering box and then drain it into a pan. Remove the other end and then throw it away. Install new hose then fill with power steering fluid. Start it up and turn the wheel left and right a few times then top up fluid again.
Old Jun 16, 2015 | 10:55 AM
LeWhite's Avatar
Make sure to the proper six point LINE WRENCH.
sammm
Sep 14, 2013 11:21 PM
japakar
Feb 14, 2013 10:03 AM
Cyberlight
Jun 20, 2011 08:46 PM
caseroj
Oct 20, 2010 08:10 AM
mel
Jan 20, 2006 08:21 AM
