Pulls to left when braking on highway
Old Oct 9, 2013 | 01:38 PM
Helter80's Avatar
Helter80 is an unknown quantity at this point
Default Pulls to left when braking on highway
When im on the highway doing about 50-65 my Blazer pulls a little to the left when i press the brakes. I know that the idler arm is shot, can that be why? The steering has a lot of slop, and I just had my brakes done. New pads, rotors, and calipers all around.
Old Oct 9, 2013 | 07:12 PM
warthogdriver's Avatar
then your right caliper is not working. when you stop and only one brake works the side that cant stop will continue forward...so if you brake and pull left then check the right side.
most likely your pads are binding up and not engaging fully.
Old Oct 14, 2013 | 11:06 PM
Shalom's Avatar
Shalom is on a distinguished road
Mine's been doing that recently. I thought one of the front calipers was hanging. Had it in to the mechanic and he said the front brakes were fine, but the cylinder on one of the rear wheels wasn't releasing. Gonna start a thread on that because I've got a question that needs answered and don't want to hijack this thread...
Old Oct 20, 2013 | 10:31 PM
87blazer4x4's Avatar
87blazer4x4 is on a distinguished road
If you just had your brakes done the mechanic could of not lubed the slide pins corectly on the calipers and one will not slide. If you know the steering is worn out that could also definitely be the problem only thing is it would also wonder around a bit if that stuff was also worn out
Old Oct 23, 2013 | 09:45 PM
SickRick's Avatar
SickRick is on a distinguished road
This is most likely a binding R. brake, as they've said. Maybe the junkyard will have an idler arm so you can replace that for cheap.
chris015
May 21, 2012 03:54 PM
mcdevin1973
Mar 21, 2012 11:44 AM
mcdevin1973
13
Jun 11, 2011 01:13 AM
sticky23
Dec 23, 2009 07:58 AM
Monkeyman
Nov 19, 2009 08:32 PM
