Pulls to the right.
Old Jul 1, 2012 | 07:49 PM
Nate1980's Avatar
Nate1980 is an unknown quantity at this point
Default Pulls to the right.
This winter I had all four balljoints,all wheel bearings, 4 new goodyears and new rotors-pads installed on all four wheels. Then of course I had it aligned. I noticed it pulled to the right. Not bad, but bad enough for the amount of money and time I have in my 2001 blazer. So of course I took it back and had the alignment checked. It was dead on. I have been driving it like this for 6 months now, no odd tire wear. I would like to get this fixed so I can cross it off my to do list. My thought is control arm bushings. Has anybody had a similar problem? What was the fix? Thanx
Old Jul 1, 2012 | 07:53 PM
50lb_cat's Avatar
Was it the same place who aligned it the first time? They might not want to admitt a mistake. Or, it could also be the idler arm.
Old Jul 1, 2012 | 08:35 PM
Rottidog's Avatar
+1 or a tie rod end, upper &/or lower control arm bushings. Drive it for 15 mins or so then pull over & put your hand on the center of the rims. If one side is hotter than the other possibly a wheel bearing was over tightened or the brakes weren't bled properly.
Is it 4 wheel drive? If so it might be a CV joint on it's way out.
Old Jul 2, 2012 | 10:31 AM
xgiovannix12's Avatar
it could also be the tire pressure check that
grensha2
Dec 26, 2010 10:36 AM
sticky23
Dec 23, 2009 07:58 AM
chris015
Jul 26, 2009 10:14 PM
doozis
Sep 24, 2008 10:38 AM
MusicMaverick
Dec 28, 2005 04:45 PM
