Rear Axle Codes
New to me 2002 Blazer and I'm going over it. After a search here I got these codes off of the glove box sticker and want to know what for rear axle is in this thing? GT4 and G80 are the only two 'G' codes on the list. The rear axle cover is rusted through to the point that it is leaking so I'm in the process of replacing it (new one on the way, old one is open and draining out). So...what does it have and can I verify it by looking at the gears in there?
Thanks, Mark |
GT4 indicates that it is a 3.73 ratio
G80 indicates that it has the automatic locker in it Most likely it is a 7.5 ring gear as that is the most common on these, but you can tell for sure by looking at the diff itself. The tell-tale sign between the two are a pair of protrusions on the bottom of the center section. https://cimg7.ibsrv.net/gimg/blazerf...4e8bf8be18.jpg |
(Post 723951)
Do like Dodge did- put a big magnet on the inside of the diff cover to catch metal particles. If that's like my 78 locker, a part breaks off and slings metal fragments around and wrecks the whole unit
There is a magnet fastened inside the cover and I wonder if one could place a super magnet on the outside of the cover if there was none on the inside.
You’re sure about the GT4? What model Blazer do you have?
Originally Posted by Billy1820
(Post 724917)
The reason I asked was that it didn’t sound familiar to me. I knew zr2 had the big rear with that ratio, but after searching found a old forum post that states that ratio was available in certain tow packages:
https://blazerforum.com/forum/steeri...999-4wd-46921/ |
(Post 724946)
Here’s something else you may find interesting, inside you’ll find how to identify axle ratios by the code stamped into the axle tube:
https://www.gmheritagecenter.com/doc...let-Blazer.pdf |
| All times are GMT -5. The time now is 01:58 AM. |
