rear axle swap
Sorry if im already asking a question that's been answered im on my phone
I have recently blew up my rear gu6 axle in my 2003 blazer. This is the 2nd one in 2 years, is there anyway of getting a bigger axle like out of a 1500 or so? I have 33s and the stock gears so im sure that isn't helping.
Thanks in advance
Thanks in advance
But the splines will line up? I took out my e brake cables anyway I just wanna get like an upgrade for the rear so a zr2 or ford explorer rear end. Im thinking ill do the zr2 swap so do I have to change shock mounts for that?
Yeah they are both "almost" bolt in axles. Keep in mind also the Z axle is 2"(I think some correct me if I'm wrong) wider so it will push your rear end out a bit. What do you have for a lift? If its still the IFS the Z axle will make your rear wheels even with the fronts.
I know El_Beautor and Okiedoak20 are both running Z axles you may want to hit them up for more info
Yea I have the ifs I wish I had a solid front axle cause the front chews through cvs and steering components.
So I have the gu6 3.42s I think that's what it is, what do I do in matching the front?
Or do I change the front gears also with these swaps?
I really appreciate the help!
The only difference was the rear u joint. It is different and I found a conversion u joint and problem solved, also had to change the u joint straps but if u pull the axle get the straps with it.will save a lot of time later. The rear wheel spacing is wider. Thats helps a lot with the front/rear width thing.
What I did was, I found a jimmy with 3.73 gears and took both axles. Sold some parts got most my money back then had the carcass towed out
Got $300 for that, then installed both axles in my Envoy. Axles ended up being free but still had to do some work to get them
