Rear backing plate
Old Dec 12, 2018 | 05:59 AM
dhirt's Avatar
dhirt is on a distinguished road
Default Rear backing plate
Hi,
I have a question about the rear backing plate. Is it really a must to remove to open the differential and remove the axle? I saw pictures of 2 pieces backing plates. But not for the s-10 blazer...
Bests,
Dominik
Old Dec 18, 2018 | 12:47 PM
RTJ49's Avatar
RTJ49 is on a distinguished road
I could not find any two piece backing plates for the 2000 style blazer. I just did the axle remove and replaced the pieces. Not as hard as you think. Cleaning the rear end cover, for a good reseal, was most of the work. Best of luck.
RTJ49
Old Dec 18, 2018 | 01:15 PM
mr.vls's Avatar
Yes you need to remove the axles to remove the backing plates. Removing the axles is not hard. Drain fluid, remove cover, remove pinion lock bolt, remove pinion shaft, push axle in and remove C clip. pull axle out.
mysain
Sep 1, 2013 06:44 PM
filoblazer
15
Sep 3, 2011 01:19 PM
99blazerman
Jan 24, 2010 11:45 AM
Alacorn101
Nov 29, 2009 06:07 PM
missu
Jan 25, 2007 05:53 PM
