rear Differential issues?
Old Dec 28, 2014 | 02:55 PM
scottb6521's Avatar
scottb6521 is on a distinguished road
Default rear Differential issues?
Hi All,
I inherited an old 88 s-10 blazer with a plow. Used only for plowing so not too worried if I need to part it out.... Here is the issue. it moves well in reverse in 2wd and 4x4. However when trying to drive forward the rear wheels seem locked almost as if the brakes are locked on. But pretty sure it is not the brakes as it rolls fine when in neutral. So I am concerned that it may be the rear differential. This is not road worthy so I am trying to decide if I should keep putting $$ into it as a plow truck as that would be really useful with my long driveway. I'm not very familair with 4wd trucks so im not sure where to concentrate my efforts..
any ideas would be appreciated!!
Thanks all....
Old Jan 3, 2015 | 08:28 AM
abig84's Avatar
its possible one of the bearings on the carrier fell apart, ive seen what your describing a few times. basically when you go one way the carrier is pulling away a bit from the pinion allowing the truck to drive but when you torque the rear end the other way it goes into the pinion locking up the differential. best way would be to pull the cover off and see if theres a bunch of metal chunks all over the place. or check the brakes anyways. possible that a pad came loose and only locks up going forward
im sure you could find a junkyard rear end for cheap and change out in a day if you want to keep the thing
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
MusicMaverick
Apr 21, 2007 02:17 PM
myetman
Apr 14, 2006 01:46 PM
Binz316
Apr 12, 2006 12:55 PM
