Rear end swap something dose'nt feel right
Old Jan 22, 2009 | 10:45 PM
l3igl3ang's Avatar
l3igl3ang is an unknown quantity at this point
Default Rear end swap something dose'nt feel right
We just done a rear end swap on are jimmy cause the origianl went out. Everything seem to go well besides the dam drum brakes god i cant stand drum brakes but any way we didnt get the ebrake hooked up but got the brakes hooked up finaly. But when i drive around 65+ feels like the back in is shakeing kind like if it was out of blance but i dont see how it could be any ideas?
Old Jan 23, 2009 | 06:58 AM
TripleBlackBlazer's Avatar
Default RE: Rear end swap something dose'nt feel right
Unbolt your driveshaft and rotate it 180 degrees and see if it remains.
Old Jan 23, 2009 | 07:00 AM
Default RE: Rear end swap something doesnt feel right
Take a look at your drive shaft and see if the u-joint may be shifted slightly in the yoke on the front of the differential. Also, I have seen it before where having the driveshaft rotated 180* may cure a condition such as this. Sounds weird I know, but may be worth trying.
Does the sensation go away at any higher speeds?
Old Jan 23, 2009 | 11:24 AM
l3igl3ang's Avatar
I have not drover it over 70mph but sometimes it seems to shake bad while others very lighty like i can have a cup in my cup holder and it rattles it.
I noticed the u joint when u hook it to the yoke dose it have to be flushed with the yoke all way around with some play in the ujoint or do i push the neededbearings holderdown flat with no play in it which is what i did
Old Jan 23, 2009 | 08:08 PM
l3igl3ang's Avatar
i think i found the problem some how my lug nuts came lose and lost them all but one before i noticed what it was. luckly i keep the ones from the other rear end and put them on tight with a break over will let u guys know tommarow it that was the problem
Junkyard Rat
Jun 19, 2013 12:17 PM
94blazer4.3ho
Sep 24, 2007 09:50 AM
redpeppers
Apr 7, 2007 04:55 AM
DS01blazer
Aug 29, 2006 04:27 AM
blazergirl15
Jul 9, 2005 03:26 AM
