Rear leaf lift 2" from leaf shackles?
Anybody had luck with leaf shackle lift?? I have a 02 Blazer 2 door.
Well no back luck with mine. If you do decide to install them start soaking the bolts now with PB. Hardest part is getting old ones off.
Originally Posted by TMM217
(Post 653547)
BTW Did you do the swap? I was thinking it'd be easy enough for my 2 jack stands and a floor jack. I have pretty much all basic hand tools. Thanks |
If the bolts will come out of the bushings then it's an easy driveway swap. Like TMM217 said, the hardest part is getting the bolts out.
(Post 653556)
So just use the floor jack on the rear diff to lift things then put the jack stands under the axle housing one for each side of the diff? Or underneath the shock absorbers? Thx for the help! |
No, you want to put the jack stands on the frame to remove any tension on the axle and leaf springs. Otherwise, you'll never get the bolts out even if the bushings are good.
Originally Posted by AJBert
(Post 653574)
If you don't destroy the old bushings, and they're in decent shape you can reuse them. The bushings are in the springs, not on the shackles.
Originally Posted by 02Goldie_Loks
(Post 653548)
Sounds like a good idea. Found some on eBay for a 2" lift.
